Activity Forums VEGAS Pro Question on Nested VEG and Alfa Channel
  • Question on Nested VEG and Alfa Channel
    Posted by Don Cobble on October 15, 2010 at 12:51 am
    I have a Project template with 3 nested Veg Files. I would like to render out the footage from two of the Veg files and just use the rendered file INSTED of the unrendered veg so my main project would run smoother ( Its loaded with effects) My problem is when I render out any of the veg files I loose the Alfa channel areas and they come out as black. I need to render out with the alfa channel so I can use for effects. IS IT Possible???
    Thank You
    PC
    I7 2.8 Ghz 8GB Ram
    Vista 64bit OS
    Nvidia FX 580 Video Card
    3-4 TB HD
    Vegas Pro 9 32bit & Vegas Pro 9 64bit & Vegas 10 32bit & Vegas 10 64Bit
    Camera
    Sony EX1 shoot in 1920×1080 30P
    John Rofrano replied 15 years, 7 months ago 2 Members · 1 Reply
  • John Rofrano
    October 16, 2010 at 12:43 am
    [Don Cobble] “My problem is when I render out any of the veg files I loose the Alfa channel areas and they come out as black. I need to render out with the alfa channel so I can use for effects. IS IT Possible???”
    Yes it’s possible. An alpha channel requires 32bits so any codec that supports 32bits (including uncompressed) will carry an alpha channel. I like to use the Quicktime Animation codec for this sort of stuff.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
