Activity Forums Canon DSLR Cameras Question on LED lighting and Canon Ti4
  • Question on LED lighting and Canon Ti4
    Posted by Suzin Daly on August 5, 2013 at 11:37 pm
    I have borrowed the Canon Ti4. In reading the manual [I’m a reader] page 176, it says…” if you shoot a movie under fluorescent or LED lighting, the movie may flicker.”
    My question – has any one shot using LED and had a flickering problem? Or is this just a warning that it could happen, but probably won’t. Just so happens we are suppose to shoot using LEDs 2-600 and a 500 watt. I really don’t want to be the messenger!
    Thanks in advance for any suggestions, advice and/or information.
    Suzin
    Suzin Daly replied 13 years, 1 month ago 2 Members · 2 Replies
  • Jonathan Ziegler
    August 6, 2013 at 3:56 pm
    The flicker they refer to is a strange sort of wavy pattern that appears with tube fluorescents. I’ve also seen it with neon lights and combinations of neon and tube fluorescents.
    I don’t see it with my 45W and 85W compact fluorescents, though and I use them a lot. You can try to work around it with a 1/50 or even 1/40 shutter (maybe a faster shutter?), but it has to do with the sensor and lighting I think – like an interference pattern or wave.
    Look for it in medium contrast areas and in strong shadow – I’ll hunt for it and then see it while its slowly creeping over a face or a wall.
    Save early. Save often.
    Jonathan Ziegler
    http://www.electrictiger.com
    520-360-8293
  • Suzin Daly
    August 6, 2013 at 4:13 pm
    Thank you for the information, it is very helpful.
    Best
    Suzin
