Activity › Forums › Adobe After Effects › Question of Null Object
  • Question of Null Object
    Posted by Clifford Li on March 13, 2020 at 10:47 am
    Hi guys, this maybe a stupid question..but i don’t know how to do this in my over 12 years after effects life …
    My question is: When you inside the composition, you may right click -> New -> Null Object. And the Null object is just like empty..with nothing..right. But when I drag the Null object into the composition from the project panel, it will be come like a 100 x 100 pixel White Solid. So, how can I turn it to be like “empty”?
    It could be not a problem if I just create another Null, but I just wanna make the project looks more organize…you know..
    Graham Quince replied 6 years, 6 months ago 3 Members · 3 Replies
  • John Williams
    March 13, 2020 at 12:56 pm
    Nulls are unique.
    Solids are normal.
    If you bring in a Solid Null from the project panel you are actually bringing in a solid.
    If you don’t want to see it just make it transparent.
    John Williams
    Soho Editors
  • Clifford Li
    March 22, 2020 at 3:33 pm
    Of course I knew…Or maybe much just “Ctrl + D” duplicate it, that much more earier..
    But that’s not the answer i am searching for.
    If Nulls just unique like shape layer, why after effects put it into a project panel…
    Maybe the question and the answer are just meaningless, but just like…Scientific spirit 😛
  • Graham Quince
    March 22, 2020 at 4:48 pm
    It is a mystery why they appear, but you can reuse a NULL from the project panel, but you do have to reduce their opacity to 0 and shift the anchor back up to 0,0 – that second bit can be important for parenting and expressions.
    You’d think/hope a Null would retain its special-ness.
    Also adjusting the opacity of a Null created in a comp doesn’t make it visible either.
    http://www.YouTube.com/ShiveringCactus – Free FX for amateur films
    https://shiveringcactus.wordpress.com/ – FX blog
