Activity Forums Apple Final Cut Pro question for today…. underlining text / underline in fcpx
  • question for today…. underlining text / underline in fcpx
    Posted by Ed Sayers on February 1, 2012 at 11:03 am
    hi
    anyone know how to underline text in the text generators in fcpx?
    i have a sentence to super up on a shot and the last word ONLY (a hyperlink) needs to be underlined
    there doesn’t appear to be an underline option in the text info window and i’ve tried importing parts of and the whole line already underlined from text and other word software – to no avail
    ideas welcome
    thanks in advance!
    ed
    Andreas Kiel replied 14 years, 6 months ago 3 Members · 2 Replies
  • Andy Neil
    February 1, 2012 at 5:15 pm
    Create the line independent of the text object. If you have Motion 5, create a title or effect project with a line that you can adjust and publish it to FCPX. However, if that’s out of your comfort zone, or you don’t have Motion 5, you can create one in the generators. Look for Shapes in Elements and add it atop your text. Change the shape to rectangle and then use the transform tools to size it down how you need it.
    Andy
    https://www.timesavertutorials.com
  • Andreas Kiel
    February 4, 2012 at 4:13 pm
    The thing with underline is quite complicated.
    Most of the Motion templates which do use text allow to use .rtf styled text. But quite often (independent of Motion or FCPX) some font style won’t allow a certain mixture of basic styles (plain, bold, italic, bold-italic) with the underline. Same as the outline style from rtf files will collide with the possible outline setting of a Motion template.
    This is something Apple has to check and resolve for a lot of apps (including their own) system wide.
    – Andreas
    Spherico
    https://www.spherico.com/filmtools
