Activity Forums Adobe Premiere Pro Question for those that have CS 5.5 & final cut studio installed….
  • Question for those that have CS 5.5 & final cut studio installed….
    Posted by Chris Borjis on July 14, 2011 at 4:20 pm
    if you have a mac with final cut studio installed AND premiere pro cs 5.5
    1. is there an option to export a prores quicktime from premiere?
    2. is there an option to CAPTURE as prores?
    It seems like it should be possible. It’s just a quicktime component.
    I can export a prores file from after effects cs4.
    thanks.
    Nik Read replied 15 years, 1 month ago 5 Members · 9 Replies
  • 9 Replies
  • Kevin Monahan
    July 14, 2011 at 4:56 pm
    The answers to your questions are yes and yes.
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Chris Borjis
    July 14, 2011 at 6:47 pm
    Yay!
    thanks Kevin
  • Nik Read
    August 11, 2011 at 1:33 pm
    thanks for this Kevin, could you tell me how to do this?!?! From the premiere timeline, you click file – export and the only quicktime options are SD ones – how do you choose HD? You can keep it as the sequence but that just gives you an mpeg right?
    Sorry to be a bit thick but I can’t see another option…
    thanks in advance for your reply,
    Nik
  • Jon Barrie
    August 11, 2011 at 2:14 pm
    To access the other codecs using quicktime look in the video tab. There are heaps inside a dropdown list!
    check this link for better prores user detail.
    https://blogs.adobe.com/VideoRoad/2011/08/a-prores-workflow-end-too-end.html
    JB
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Nik Read
    August 11, 2011 at 2:44 pm
    thanks for that Jon,
    I’ve just tried a short export using an XDCAM EX codec and whilst the title sequence was ok the footage was all blue…!!!!
    Any ideas what I was doing wrong? I changed the size to 1920 x 1080 and square pixels, apart from that left it as quicktime.
    thanks
    Nik
  • Jon Barrie
    August 12, 2011 at 2:28 am
    Are you using CUDA acceleration? If so switch it back to Software only mode. Some cases the CUDA Hardware accleration, especially on cards not officially supported but not exclusively, can show this bug.
    Let us know with a test render.
    Cheers,
    JB
    Jon Barrie
    aJBprods
  • Nik Read
    August 12, 2011 at 9:34 am
    thanks Jon,
    I have a Matrox MX02le on my desktop suite but this was done on my laptop, which is standalone. How do I turn on the software only option?
    All I’m looking to do is to create a final file for archiving, the same quality as the timeline. I only seem to get the option of making an mpeg file when I check the match sequence settings box and ideally I’d like a file that I can open in FCP7 when I need to. Any ideas on the best way to export from PPro 5.5? With FCP7 it was just a case of file-export-current settings and you had a .mov
    Prores files are so large and I just don’t need them that big.
  • David Foster
    August 12, 2011 at 6:33 pm
    I believe the software only option is turned on by default, but I could be mistaken.
    Are you outputting via your Matrox, or are you just creating a hard drive copy?. If hard drive only, import your EX footage into Premiere, then right click on the footage. You should get an option to create timeline matching the footage.
    Dave
  • Nik Read
    August 12, 2011 at 8:49 pm
    thanks Dave,
    that’s a great tip that I didn’t know. It’s just for archiving so no need to use the Matrox for that.
    all the best guys,
    Nik
