Activity Forums Maxon Cinema 4D Question for the 3D pros…
  • Question for the 3D pros…
    Posted by Chris Poisson on December 4, 2006 at 2:24 pm
    My 3D experience is lmited, but I do use Invigorator and have had some success using dxf models inside it. What I want to know is, can a dxf file be converted to an obj, and if so, what do I need to do it with? It would need to be a Mac-based solution.
    I also own Kinemac, and it only takes obj files. I want to try the same animation in it and compare the looks, they work so differently.
    I have done a Google search on this without much luck.
    Philo Calhoun replied 19 years, 9 months ago 3 Members · 2 Replies
  • Brian Jones
    December 4, 2006 at 4:15 pm
    if you are in this forum because you have C4D as well as Invigorator and Kinemac then C4D will do it. Open the DXF then export to obj.
  • Philo Calhoun
    December 4, 2006 at 6:53 pm
    I have found some problems with importing dxf objects in C4D. If you have autocad, you might export a 3ds object instead and use C4D to convert that to a obj file.
