Activity Forums Adobe After Effects question for mac 8-core users
  • question for mac 8-core users
    Posted by Jay Brown on April 23, 2008 at 1:16 pm
    Hi
    Recently was lucky enough to upgrade to an 8core mac pro recently (8800 gfx card). Although I have only 2G of Ram at the moment I was expecting it to work with trapcode particular and form a little quicker.
    When the wallet recovers i will be putting more ram in there (4G?- total 6G) but untill then have any of you experienced the same thing?
    Any magic settings Im missing (new to macs)
    Open GL has been tried as well which does make the scrub smoother
    I guess i’ll get a few mails back saying its just a RAM thing but just in case Im missing something I thought Id ask anyway
    thanks in advance
    Kevin Camp replied 18 years, 5 months ago 2 Members · 6 Replies
  • Kevin Camp
    April 23, 2008 at 8:43 pm
    the first thing you need to do is enable ae to use those extra cores to render multiple frames simultaneously in the multiprocessing preference. i believe you need a minimum of 512mb of ram per core, adobe recommends 1gb per core and most users will tell you get 2gb per core.
    with the 2gb of ram that you have, after enabling multiprocessing, go the the memory and cache settings and try a max ram cache setting around 30% to allow ae to use a few more of your processing cores. also, since you are a little short on ram, i’d suggest not running any other applications while using ae, to avoid limiting the available ram.
    next, i would disable opengl for previews all together in the preview preference. opengl is not compatible with multiprocessing in ae, so you will lose the multiprocessing for previews if opengl is enabled.
    i would try to shoot to add around 8gb of ram when you get a chance. and you may want to buy 2gb sticks so you will have room to expand, particularly if you want to go hd. fyi, third party vendors, like otherworldcomputing.com, have better prices than apple for ram.
    also, as you install ram, you would prefer to install like sized ram in respective slots on each riser… so if you purchased 4x2gb sticks (8gb), your installed slot allocation would be something like this:
    riser a – slot 1: 2gb
    riser a – slot 2: 2gb
    riser a – slot 3: 1gb (orig ram)
    riser a – slot 4: 1gb (orig ram)
    riser b – slot 1: 2gb
    riser b – slot 2: 2gb
    riser b – slot 3: empty
    riser b – slot 4: empty
    this configuration would give you a total of 10gb (8gb new and 2gb original). the first 8gb of ram will benefit from the performance gains of the interleaving between risers a & b, but you’ll still be able to use the original 2gb of ram in new slots. you can squeak out a bit more performance if you were to add 2x1gb sticks to the last 2 slots, but if you think you may upgrade further and add 4x2gb sticks for a total of 16gb, then you’d be throwing away (or ebaying) the 1gb sticks.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Jay Brown
    April 24, 2008 at 8:09 am
    Thanks for that Kevin
    Very appreciated
  • Jay Brown
    April 24, 2008 at 8:19 am
    Hi Kevin
    In true Columbo fashion ‘ just one more question’
    Having just reading your previous post regarding RAM configurtions and splitting it over the 2 risers if i get the 4G I can afford would you regard the following to be a suitable set-up
    riser a – slot 2: 1gb (orig ram)
    riser a – slot 3: empty
    riser a – slot 4: empty
    riser b – slot 2: 1gb (orig ram)
    many thanks
  • Kevin Camp
    April 24, 2008 at 3:30 pm
    nope… you’ll have to add the matched pairs together. so i believe the best way to install that configuration would be like this:
    riser b – slot 1: 1gb
    you won’t lose that much performance benefit from by not utilizing the interleaving between risers a and b. here is some good info and benchmarks for various ram configs, if you’d like more info, ‘columbo’ 🙂
    now, i have to admit i’m having trouble figuring out if, since you can’t benefit from the interleaving of the separate risers, can you just add all the ram to riser a…? it may not matter, but i can’t seem to find anything definitive.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Jay Brown
    April 24, 2008 at 4:54 pm
    Thanks again
    Great link
    With what you suggested I tried rendering a small particular heavy file b4 and after style. With the mutlicore enabled and ram cache dropped the render time dropped from 59sec to 34sec.
    Impressive drop even on only 2G Ram
  • Kevin Camp
    April 24, 2008 at 7:26 pm
    cool…
    if you want to continue ‘optimizing’ you ram and mulitprocessing to suit your typical projects, in the multiprocessing preference, ae states how many ‘additional processors’ will be used based on you current ram cache configuration.
    so, you can make tweaks to the ram cache settings, check out the multiprocessing effect, then choose edit>purge>all and do a render of a typical comp to test any benefit of the new settings.
    you may not see too many problems with limited ram if you work in sd, don’t use a lot of time based effects (echo, cc widetime, cc force motion blur….) or ae’s 3d too much….
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
