Activity Forums Panasonic Cameras Question for Jan DVCpro HD Encoder HDSDI input to SDTI with VANC
  • Question for Jan DVCpro HD Encoder HDSDI input to SDTI with VANC
    Posted by David on April 11, 2005 at 12:50 am
    Jan or others that may have the answer.
    Is their a encoder to go from HD SDI with embedded audio encoded to DVCpro HD output SDTI passing the VANC for live feeds(could have a P2 card reader). Prefer not to EE though a VTR.
    And a decoder to make a matching set.
    David replied 21 years, 5 months ago 2 Members · 2 Replies
  • Jan Crittenden livingston
    April 12, 2005 at 2:08 pm
    Hi David,
    Not sure I understand your question. Maybe just thick-headed this am.
    The HD-SDI is embedded audio, but from what? do you want an SDTI stream to com from and to what? Does that make sense?
    Best,
    Jan
    Jan Crittenden Livingston
    Product Manager, DVCPRO, DVCPRO50, AG-DVX100
    Panasonic Broadcast & TV Systems
  • David
    April 13, 2005 at 3:56 am
    Jan,
    I was looking for the DVCpro HD equivlent of the Evertz PKG7770MFC-HD and PKG7770MFD-HD uses the HDcam Codec.
    Or if you have a list of broadcast video server’s that uses the DVCpro HD codec.
    It is a to do with using the same codec for aquistion, editing, disturbution and broadcast playout before high compression in the transmission system. This question has come out of the discussion of DV100 vs DNxHD vs CFHD. Maybe I should transcode and at what point.
    HDCAM version HDcam camcorder Omneon server with Evertz encoders Xpri editors
    DNxHD version Ikegami camera Avid server avid editors
    Dvcpro HD version Panasonic camera Omneon server with ? encoders Multiple options for editors. The only product I can see to fill the ? is a VTR with a HD SDI Input and a SDTI output option.
    I hope this helps to understand the orginal question.
    Regards David
