Activity Forums Compression Techniques Question for Ben…if you’re still around
  • Question for Ben…if you’re still around
    Posted by Barlow Elton on February 14, 2006 at 9:51 pm
    Hi Ben,
    I’m trying to convert 1080i DVCPRO HD (recorded live from Canon XL-H1 to Kona SDI card) into DVCPRO 60p, and then convert to DVCPRO 24p for a true slo-mo look.
    A person in the HDV forum said you recommend Compressor for this chore. Is this correct? I’m rendering out a 5 sec. clip and it’s amazingly slow on my G5 dual 2.7…I checked a bunch of motion adaptive stuff in the frame controls area of the inspector, which is why I think the render is going slowly.
    Any insights you could share?
    Barlow
    Ben Waggoner replied 20 years, 7 months ago 3 Members · 3 Replies
  • Daniel_l
    February 15, 2006 at 1:47 pm
    Although I’m obviously not Ben and therefore not qualified to answer this question, you might want to check this out while you are waiting for him to respond.
    https://www.creativecow.net/articles/solorio_marco/twixtor_review/index.html
  • Barlow Elton
    February 16, 2006 at 7:49 am
    Hey, thanks for that link.
    btw, I did figure out how to do the conversion. It looks amazing, and the slow motion is amazingly smooth too.
  • Ben Waggoner
    February 21, 2006 at 7:45 pm
    Sorry, I’m on paternity leave this month, so not checking the boards as much as usual.
    Glad it worked for you. The optical image flow stuff is amazing, albeit amazingly slow…
