Activity › Forums › Adobe After Effects › Question for Andrew Kramer or anyone else who can…
  • Question for Andrew Kramer or anyone else who can…
    Posted by Alexander Gao on January 10, 2007 at 10:59 pm
    Hi Andrew,
    I saw your FPS converter tutorial over at video copilot and it was great. I was wondering though, is there a way that I can achieve the look of 24p from 29.97 NTSC, but still be able output to a 29.97 fps video file for DVD (as DVD’s only accept 29.97, right)?
    Alexander Gao
    Andrew Kramer replied 19 years, 8 months ago 4 Members · 3 Replies
  • Mark
    January 10, 2007 at 11:17 pm
    Back in the day, before I had magic bullet, the following was my recipe that I found worked for me…
    Video is set to lower field de-interlace in interpret footage dialog.
    Comp 1 (video is placed in this comp) frame rate set at 60
    comp 2 (comp 1 is placed in this comp) frame rate set at 29,97
    comp 3 (comp 2 is placed in this comp) frame rate set at 23.976
    For a better film look, in comp 3 I liked to to duplicate the comp 2 layer and use the Meyer’s instant sex method, using an adjustement layer over top to control levels and also to add noise.
    Now add comp 3 to the render queue and make sure field render is set to lower, and that you select 3:2 pulldown (select the last option in the pulldown).
    This will usually create pretty nice results, although I have had some issues with certain DV video. Magic bullet does a superb job of this.
    Hope this helps
    Mark
  • Majorasshole
    January 11, 2007 at 12:05 am
    Most new DVD players will play 23.976 fps burned DVDs and will just replicate frames to add in the pulldown frames. You gain 3% more playing time.
  • Andrew Kramer
    January 11, 2007 at 1:45 am
    DVDs do play 23.976( probably the best choice too) but if you need a 29.97 dvd, add a pulldown to the 24p footage in AE. When you render add a pull-down and it will make the 24p fit into a 29.97 comp.
    I hope this helps,
    Andrew
