Activity Forums Apple Final Cut Pro Legacy Question: Convert 1280 × 720 Pro Res to 1920×1080
  • Question: Convert 1280 × 720 Pro Res to 1920×1080
    Posted by Mike Snow on July 30, 2012 at 7:49 pm
    Usually finalize all projects to 1280×720 but client wants 1920×1080 version after footage was pro res.
    Tried media manager but makes movie file lag.
    Shane Ross replied 14 years, 1 month ago 2 Members · 3 Replies
  • Shane Ross
    July 30, 2012 at 7:52 pm
    Use Compressor.
    Wait, they want ALL the footage and the cut to be 1920×1080? Not the final output? Compressor will work for the output…but why do they want all the media and sequence to be 1920×1080 if it wasn’t shot that way?
    Media Manager is the way to do this. Retains all the metadata like reel number and source timecode. Compressor won’t.
    Shane
    Little Frog Post
  • Mike Snow
    July 30, 2012 at 7:55 pm
    Thank you for responding so fast.
    They just want the final .mov file to be 1920×1080 . Are there any specific setting on media manager I should follow?
  • Shane Ross
    July 30, 2012 at 8:29 pm
    If it’s just the final output, I wouldn’t use Media Manager. That’s not what it’s designed for. I would output a self contained QT movie using the current settings, then use Compressor to convert to the dimensions and codec they require.
    YOu can adjust the frame size in the inspector.
    Shane
    Little Frog Post
