Activity Forums Apple Final Cut Pro Legacy Question – best way to import EX1 MP4 files
  • Question – best way to import EX1 MP4 files
    Posted by Don Cobble on April 25, 2011 at 3:33 am
    I have an older MAC Pro dual Xeon 2.66 and a matrox mini max, 13GB ram
    and a striped raid media drive. Trying to get all I can out of this machine. I want to edit from my EX1 1920×1080 30P MP4 files. I have snow leapord Final cut Pro suite with FCP 7. What is the best way to bring them into my mac and what format should I use? I downloaded the ex XDcam clip browser it makes MFX files. Is this the best?
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    Intensity Pro
    3-4 TB HD
    Vegas Pro 9 32bit & Vegas Pro 9 64bit & Vegas 10 32bit & Vegas 10 64Bit
    Camera
    Sony EX1 shoot in 1920×1080 30P
    Thanos Papadopoulos replied 14 years, 3 months ago 6 Members · 11 Replies
  • 11 Replies
  • Shane Ross
    April 25, 2011 at 3:49 am
    [Don Cobble] “I downloaded the ex XDcam clip browser it makes MFX files. Is this the best?
    The CLIP BROWSER will make Quicktime files in the XDCAM codec for FCP do work with. The best? No, but not bad. For THE BEST you would take those QT files and Media Manager in FCP to RECOMPRESS those to ProRes. Unless you don’t have that much drive space, then just use the XDCAM QT files, but use a ProRes sequence…or change the render controls to render out ProRes.
    Shane
  • Don Cobble
    April 25, 2011 at 4:32 am
    If I recompress those into Pro res will my old MAC pro be able to edit them? I am new to mac. I am a PC person trying to convert to MAC but it is New Way old machine
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    Intensity Pro
    3-4 TB HD
    Camera
  • Shane Ross
    April 25, 2011 at 4:35 am
    As long as you have FCP 6, you will be able to edit them. Even a G5 can…although it would struggle a bit.
    Shane
  • Don Cobble
    April 25, 2011 at 5:04 am
    Thank You – will try it out
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    Intensity Pro
    3-4 TB HD
    Camera
  • Andy Mees
    April 25, 2011 at 5:41 am
    Hey Don
    You’ve got a few options available to you, but most are based around simply rewrapping into a Quicktime container (MOV) the XDCAM EX footage thats inside those MP4 files. Thats because FCP itself already understand the XDCAM EX movie format, just not the native MP4 container that media comes in. Sony offer a few (free) tools for this, theres XDCAM Browser 1.2.1 (which is a combination of their Clip Browser and XDCAM Transfer tools), theres XDCAM Transfer 2.12, and then theres their XDCAM EX Log and Transfer plug-in for FCP itself. XDCAM Browser is the latest incarnation of their tools but the latter more mature options are generally still more popular.
    https://support.sonybiz.ca/esupport/Navigation.do?os=Mac
    Another option is a Quicktime component that will allow you to work natively with the MP4 files such as Calibrated Software’s MP4 EX Import component https://www.calibratedsoftware.com/MP4EXImport_Mac.asp
    A lot of people do struggle with editing this MPEG HD format natively though, and in those cases the only real option (as Shane has already explained) is to transcode the footage to a more edit friendly format such as Prores
    Hope it helps
    Andy
  • Gary Askham
    April 25, 2011 at 1:15 pm
    Your Mac is perfectly adequate for editing XDCAM. I don’t know why you are worried.
    Sony have really over-complicated their lineup of apps and drivers needed for working with XDCAM. It’s a bit of a joke really. Andy’s explanation is about as good as it gets.
    The main decision you are going to have to make is if you want to work with the native XDCAM (rewrapped as QuickTime’s using one of Sony’s applications) or to work with ProRes.
    Advantages of working with XDCAM – takes up less drive space, less transcoding.
    Disadvantages with working with XDCAM – compressed, unstable on some systems.
    Advantages of ProRes – visually lossless, very stable.
    Disadvantages of working with ProRes – Larger file sizes, transcoding time.
    FCP and Avid Technical Support
    Air Post Production
    Shoreditch – London
  • Gabriele Gismondi
    September 23, 2011 at 6:29 pm
    hi, is that good for you if i just plu the camera to my bookpro and simply copy the whole card and place them on the hard disk. then, at home, open the EX Clipbrowser and convert. would it be a faster way in an outdoor condition and not having so much time to empty/backup the cards content? should i copy the entire card or just video files? thanx
  • Andy Mees
    September 24, 2011 at 1:23 am
    Hi Gabrielle
    You can and should use Sony’s XDCAM EX ClipBrowser (or XDCAM Browser) to do a checksum verified data copy the full card contents including folder structure to your laptop whilst you’re in the field. It’s far preferable to just doing a manual drag copy as you propose, as there is no guarantee that the copy is 100% successful with such a method (corrupted data during a manual copy is unlikely, but these copies are going to be your camera master’s and you can’t afford to risk it … you can’t just copy it over again if you’ve already reused the card).
    Cheers
    Andy
  • Gabriele Gismondi
    September 24, 2011 at 9:00 am
    thanks Andy, I’ll follow your way so!
  • Thanos Papadopoulos
    June 5, 2012 at 11:35 pm
    I plan to use Quicktime files in the XDCAM codec for FCP7 do work with (I need files as small as I can without any loss in quality) and prores 422 files from PANASONIC TM700 (I guess I should go with 422 and not 422Lt?). But my basic camera (with most of the clips) is Sony with XDCAM codec files. So I’m wondering if I should match my timeline with the XDCAM files and render to prores 422, or to match my time line with prores 422 files.
