Activity Forums Adobe Premiere Pro Question about what the selections do on the visual and audio channel in Premiere
  • Alex Udell
    May 15, 2014 at 9:41 am
    you are looking at source media to destination sequence patching.
    Left side represents the tracks available in whatever source is in your source viewer. enabling or disabling those means that when an edit (insert/overwrite) is performed, only those trax of material from source will be edited to the timeline
    Right side represents tracks available in the sequence.
    enabling and disabling those determines how those tracks will be effected by the insert or overwrite edit you are about to do.
    so if you have material on multiple tracks in the sequence, and you do an insert edit with only some of the destination tracks highlighted…then only those tracks will ripple when the edit is performed.
    same is true for overwrite – if not all sequence tracks hilighted…then only the tracks hilighted will be overwritten.
    where there is no corresponding source to destination “patch” black is overwritten or inserted.
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Joseph W. bourke
    May 15, 2014 at 1:47 pm
    Alex’s info is right on the money – you should also take a look at this video on the Adobe help site:
    https://helpx.adobe.com/premiere-pro/using/source-patching-track-targetting.html
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
