Activity Forums Adobe Encore DVD Question about video that appears to be changed in Encore
  • Question about video that appears to be changed in Encore
    Posted by Jan Janowski on May 7, 2018 at 12:16 am
    CS6 programs… I’ve created a set of SMPTE 219 bars that show full (0-255) levels…. White in 219 is 235, but I added a white box at 255…. and partially overlapped 219 bars white….. So at a glance I can see if levels are 0-235 (both ‘whites’ look same) or 0-255 (Both ‘whites’ have 2 different (observable) white levels…
    Whereas in YC waveforms in Premiere CS6 shows both 235 an 255 levels on this video… and Matrox MX02 SD and HD HDMI outputs shows two different levels of white on TV: (235 from SMPTE 219 white, and the Box with 255 levels.).. On Matrox MX02 SDSDI output on a Tek 601A scope, I see two different white levels: 235 & 255….
    I don’t have a physical scope that displays HDSDI ($$$) but since waveform monitor in Premiere and MXO2 HDMI with HD Footage shows two different white levels 235 & 255, I assume HDSDI shows two as well!
    This 0-255 SD & HD video can be exported to a file From Premiere, and re-imported into Premiere and again — and again, I see two different white levels on the MX02 output…… So Premiere is inputting and outputting 0-255… faithfully…
    HOWEVER…..
    When I take either the 0-255 file that I exported from Premiere into Encore, OR, Dynamic Link to Encore from Premiere with that 0-255 file on the timeline….. When I burn to DVD or BR….On Playback to TV (that passes 2 whites in Premiere via MXO2) does not pass 2 white levels, and appears to clip one below black level, too. Encore appears to limit 0-255 to 16-235 video levels…. Both white levels look the same, and black pludge below 0 is clipped.
    Matrox Output is active in Encore, and HDMI and SDSDI Scope (Remember: No HDSDI Scope here!) show what I believe is 16-235…. when 0-255 is fed to Encore…. (There is no access to Matrox MX02 Settings in Encore like there is in Premiere..)..
    My question…. Can Encore Pass along 0-255 video to DVD or BR???? Or is it limited to 16-235?
    I can find settings within my Sony BR Players (And also TV SETS) where I can force 16-235 or 0-255, and when set for 0-255 on BR and TV, and Premiere sent 0-255 to Encore, I seemingly only get 16-235 at DVD or BR…. So I’ve seemingly answered the question…. But I’d like confirmation…
    Can someone confirm that Encore via DVD or BR will not support 0-255 video, and in fact changes it to 16-235? and If I’m wrong (and I so hope I will be……) Please explain how you did it….
    Thanks much!!!!
    Looking for 1939 Indian Motocycle
    Jan Janowski replied 8 years, 4 months ago 2 Members · 10 Replies
  • 10 Replies
  • Jeff Pulera
    May 7, 2018 at 2:14 pm
    You lost me part way through with all the levels business…but here’s my take on it. If you export from Premiere as MPEG-2 DVD, then Encore will not touch the videono trancoding – so whatever was exported from Premiere will be what is playing off the DVD. Meaning no change in levels should happen.
    In fact, you should be able to Import the .m2v video you exported back into Premiere and check levels there to see what you have before going to Encore.
    So figure out the correct bit rate to encode your program to so that it fits the DVD (to avoid transcode to fit) and export as MPEG-2 DVD which provides .m2v video and .wav audio. By default, Encore will leave the video alone, and audio gets transcoded to Dolby Digital.
    Jeff Pulera
    Safe Harbor Computers
  • Jan Janowski
    May 7, 2018 at 3:20 pm
    Thanks Jeff. I was specific as to levels because it was needed to be. I will not have access to system to try the MPEG/-DVD encoding method. I’ve posted a skmelar post a Matrix site as I’m seeing 16/235 on Matrox Output as well, and Matrox does not have setup screen accessible via Encore, yet outputs video via Encore. In Premiere you have to turn on Allow Super Black And Allow Super White to allow 0-255 levels.
    I hate having two possibilities with me having access to neither with certainty!!!!
    That’s why I have been asking if Encore passes 0-255.
  • Jeff Pulera
    May 7, 2018 at 4:19 pm
    Hi Jan,
    I did not mean to discount your attention to detail regarding measurement of levels at various stages, rather it is my ADHD that makes it hard for me to follow ????
    As I’ve not produced video for broadcast, have never really played with or paid attention to levels – if it looks good by eyeball, that has worked for me.
    But again, if you can provide a spec-legal .m2v file into Encore, it will NOT transcode it, therefore I don’t see where it would be doing anything whatsoever to levels – they are and should thus remain whatever is in the .m2v file exported from Premiere/Media Encoder. Never recommended to let Encore transcode your files – feed it what it desires.
    I used to use MXO2 – I could be thinking of older RT.X2 here as well – but I recall in the Matrox output setup, there was an option to “Add 7.5 Setup” or something like that. Meaning if I were editing footage that used 7.5 IRE as the baseline rather than 0, such as MiniDV footage, then I would check that button, otherwise when viewing the Matrox output on a video display, blacks would (falsely) look washed out, which might prompt editor to want to color correct when in fact source video blacks were fine, but the output from Matrox was “off” if that makes sense.
    Jeff Pulera
  • Jeff Pulera
    May 7, 2018 at 4:45 pm
    Curious – what video format are you actually importing into Encore then, which it transcodes?
    Jeff
    Jeff Pulera
  • Jan Janowski
    May 7, 2018 at 5:00 pm
    No sweat. Let me get to system and I’ll provide file type and try the re-render for DVD & BR. You mention.
    This is not a color space conversion or setup issue. I should be able to get this info tomorrow afternoon.
  • Jan Janowski
    May 10, 2018 at 11:37 am
    As you know, a CS6 Master license allows you to install on a Desktop and a Laptop….
    My Desktop has a Matrox System, Laptop does not…. In earlier post I mentioned that there was a possibility that Matrox could be part of this issue (No email from them yet).. So to Avoid the Matrox possibility…. I did today’s tests on Laptop….. To remove Matrox as a possibility of that clouding this issue…
    So,, I copied the 2 files (H264 SD and HD) that shows 0-255 levels on my desktop system in Premiere —- to my laptop, and imported that into Premiere on my laptop……
    I then exported that from Premiere as MPEG2-DVD or MPEG2-BR and brought each into Encore as DVD or BR project, set as first play, and then burned a DVD and BR from that footage….
    The DVD and BR that was burned was played back on a Sony TV and Sony BR player… Each set for Auto format, or Y,CB,CR 422, or Y,CB, CR444, or RGB(16-235). or RGB(0-255)……
    and both the DVD or BR disc created in Encore (With the video footage that shows 0-255 on Premire/Matrox system at SDI or HDSDI or HDMI output to the same Sony monitor used on the Premiere/Matrox test, where 0-255 was seen!
    So, I ask again…..
    Can Encore burn video with 0-255 levels, or is it limited to 16-235? I’m hoping that I’m doing something wrong….
  • Jan Janowski
    May 10, 2018 at 11:42 am
    Gee I wish you could edit your posts…..
    Both the DVD and BR I created shows 16-235 levels from the 0-255 levels presented to it from Premiere via the MPEG2-DVD or MPEG2-BR …….
    I’m hoping to faithfully create a BR (At Least) or DVD with 0-255 levels…
  • Jan Janowski
    May 10, 2018 at 11:45 am
    Later today or tomorrow at latest, will try this same approach on Desktop/Server, in the off chance that Matrox is the reason why I’m seeing 0-255 in Premiere …… I’ll render to MPEG2-DVD and MPEG2-BR as you requested and try the burn that way and test playback again….
  • Jan Janowski
    May 10, 2018 at 3:25 pm
    I seem to be solving one question to ask another….
    Desktop Server…. Render to H264BlueRay out of Premiere…. Into Encore…. Works on BR disc… Now why not on Laptop?
    I have more tests to do….
  • Jan Janowski
    May 10, 2018 at 7:14 pm
    I will put a step by step procedure for doing this… in another post at this, and Premiere’s forum, as there are procedures that need to be followed……
    Watch for it!
