Activity › Forums › Adobe After Effects › question about using blur filters
  • question about using blur filters
    Posted by Phredrek on August 19, 2008 at 10:26 pm
    Hi everyone!
    I’m concerned about what is happening to the edge of my frame when I apply blur to my footage. The more I blur it the more area it makes transparent around the edges. Isn’t there a way for it not to go transparent and just somehow fill it in?
    I’m using AE-CS3 on a quad windows system with 4gigs of ram.
    mostly using the directional blur
    thanks!
    Frederic
    Phredrek replied 18 years, 1 month ago 3 Members · 3 Replies
  • Peter O’connell
    August 20, 2008 at 4:54 am
    Hi, you could try using box blur with 2 iterations and check on the repeat edge pixels property.
    Hope this helps
    Pete
    roguekeyframe.com
  • Brendan Coots
    August 20, 2008 at 6:32 am
    Regardless of which blur type you use, tick off the “repeat edge pixels” option.
    As a side note, for general purpose use Fast Blur is the way to go. It is the exact same underlying code as Gaussian Blur, but with a substantial performance boost.
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
  • Phredrek
    August 20, 2008 at 2:28 pm
    hi and thanks for replying!
    that is kind of my question, where is the tick for repeat edge pixels? I can’t seem to find it.
