Activity Forums VEGAS Pro Question about transcoding
  • Question about transcoding
    Posted by Michal Bronec on May 26, 2012 at 10:33 pm
    I have a 5minute video in PAL DV Widescreen and I need to upload it to Vimeo. The problem is the video is 1,2 GB. So I need to shrink it (because my Vimeo limit is 500MB). I tried to use MainConcept AVC, progressive, resolution same as the original and variable bit rate (8-16 000 000 bps), but the result is not so sharp as the original. It little bit blurry. What should I do?
    Mikhail Petrushin replied 14 years, 3 months ago 3 Members · 6 Replies
  • Mikhail Petrushin
    May 27, 2012 at 12:28 am
    Vegas deinterlacer is the problem, imho.
    I’m using other tools for deinterlacing and upscaling my PAL Widescreen videos before uploading them to Vimeo/Youtube or editing in Vegas.
    P.S. I’m using SimpleSlugUpscale (it uses AVISynth with some plugins and VirtualDub). If you upload somewhere a piece of your source I can upscale it with this technique for you. After that you will decide if it worth to use it or not.
  • Aleksey Tarasov
    May 27, 2012 at 9:45 am
    PAL DV Widescreen has non-square pixel aspect ratio (PAR = 1,4568)
    If you want 16:9 you should render as 640×360 PAR 1.0 (with a little cropping) or you can upscale video to 1280×720.
    Vimeo Compression Guidelines
    Vegasaur – automation plugins and tools for Sony Vegas Pro
  • Michal Bronec
    May 27, 2012 at 11:56 am
    Actually, I tried to upload the original PAL DV Widescreen file to YouTube and the result was sharp as the original. The Only problem was flattened image because of non-square pixel aspect ratio.
  • Michal Bronec
    May 27, 2012 at 12:03 pm
    The other thing I noticed is that the video uploaded on the Vimeo has much more contrast then the original file (the highlights seems to bee little bit overexposed and the shadows crushed).
  • Michal Bronec
    May 30, 2012 at 8:02 pm
    Is this the method you were talking about Mikhail?
    https://www.bubblevision.com/underwater-video/Vegas-YouTube-Vimeo.htm
  • Mikhail Petrushin
    June 1, 2012 at 2:07 am
    Nope. I use another workflow:
    1. Upscale all my SD videos using SimpleSlugUpscale (I simplified process by integrating all _my_ typical settings into simple bat-script and adding an action button on Total Commander toolbar)
    2. Edit resulting videos in Vegas
    Both workflows use the same AviSynth/QTGMC deinterlacer (+noise remover).
