Activity › Forums › Canon Cameras › Question about TC syncing the XL-H1 and XH-G1
  • Question about TC syncing the XL-H1 and XH-G1
    Posted by Howard Brodsky on February 3, 2008 at 1:25 am
    Both of these cameras have jack packs for genlock and TC synchronization. I have both cameras set for HD 1080/60i in drop frame and rec run modes. I’ve got a single SDI/BNC cable going from the XL-H1’s TC out to the XH-G1’s TC in.
    Should I set the XL-H1 for int user bit and the XH-G1 for ext user bit?
    Can I disconnect the cable after these cameras handshake and still maintain TC sync?
    Donald Berube replied 18 years, 7 months ago 2 Members · 2 Replies
  • Howard Brodsky
    February 3, 2008 at 8:06 pm
    Followup,
    Both cameras were actually set to int user bit. I assume there is some automatic priority over-ride involved in the time code syncing process. The two cameras synced up perfectly. I removed the cable and the XH-G1 was still in sync with the XL-H1.
    This was just to test out the system and I had a test tape in the XL-H1 which ran out. The XH-G1 still continued with the same “synced” time code stream. Even after I turned the XH-G! off, when powered up it was still in the same “synced” timecode stream! Even after I removed the battery and replaced it – the XH-G1 was still in the same “synced” timecode stream!
    I created a monster that has run amok! How do I stop this thing?
  • Donald Berube
    February 9, 2008 at 5:04 pm
    Howard,
    Thank you for your follow-up.
    – Don
    DONALD BERUBE
    https://noisybrain.com
    https://www.bosfcpug.org
    https://fcpugnetwork.org
