Activity Forums DSLR Video Question about recording format.
  • Question about recording format.
    Posted by James Hark on January 6, 2016 at 2:40 pm
    A client wants to be able to submit his video to Much Music. This is what they say the format needs to be,
    “Tapes delivered to CTV must be XD-HD in the 50Mb, 1080i/ 59.94 and signal parameters must conform to SMPTE
    274M with no visible video impairment such as blocking errors or pixelization artifacts”
    So I really have to shoot in 60 fps? How do I make it not look so “real” and still have the 24 fps “cinematic” feel while keeping it in 60 fps?
    James Hark replied 10 years, 8 months ago 3 Members · 3 Replies
  • Jeff Pulera
    January 7, 2016 at 2:45 pm
    Dave nailed it, but I would add, do they really need to get a tape from you, or can you deliver a digital file? Next issue, most cameras shoot at around 24Mbps, maybe 35Mbps for XDCAM. So what are you shooting with? Shooting at 24Mbps and converting to a 50Mbps format for delivery does not give the source 50Mbps quality…will they notice?
    Many broadcasters have requirements that the source be at least 50Mbps, and having 4:2:2 color while most cameras compress with 4:2:0 color.
    One way to really improve the source would be to use something like an Atomos Ninja 2 which takes the live feed from the camera and records as Apple ProRes, thus giving you the high-bitrate 4:2:2 source recording to work with, having far less compression than what the camera would provide on the SD card natively.
    Jeff Pulera
    Safe Harbor Computers
  • Aaron Star
    January 7, 2016 at 8:55 pm
    “XD-HD in the 50Mb, 1080i/ 59.94”
    The TV station is probably operating on Sony XDCAM422 equipment. You can shoot pretty much whatever you want, but just need to deliver in 1080i(29.97 interlaced or 59.94 fields/s) rendered to Sony XDCAM422, which is a 50Mbs MPEG2 format in an .MXF wrapper.
    https://en.wikipedia.org/wiki/XDCAM
    Shooting in 422 color will help with this, but is not necessary, as the TV station is likely buying your content an not the production color qualities. Shooting your DSRL in 1080i mode, editing in 1080i, and then rendering to XDCAM422.MXF will more than likely be accepted by the station. The station will likely have the equipment to accept the .MXF file and play it directly, or convert it to tape if they are really old school. The main thing to watch are your black levels when you do the conversion from 4:2:0 to 4:2:2. Verify with your video scopes the conversion is staying the same.
    XDCAM422 can be rendered from Sony Vegas Pro Edit, and the recent Sony Catalyst series of products. Sony also makes a downloadable plugin for AVID and Final Cut, with some of the most recent versions support exporting it native.
    https://pro.sony.com/bbsc/ssr/micro-xdcam/resource.demos.bbsccms-assets-micro-hdtapelessworkflow-solutions-XDCAMEXWorkflowAssets.shtml?XDCAM
    You may also want to see if the Station is working with
    https://www.sonymcs.com/
    as that may also be an alternative delivery solution.
  • James Hark
    January 12, 2016 at 2:14 pm
    wow thank you I think I have all the info I need in this post. really appreciate it everyone.
