Activity › Forums › Adobe After Effects › Question about Premiere CS5 to AE CS5 Workflow
  • Question about Premiere CS5 to AE CS5 Workflow
    Posted by Michael Frantz on June 1, 2011 at 8:17 pm
    Good afternoon. Quick question or clarification.
    I have a movie project that I’m editing in Premiere Pro. As I cut and work through that workflow I right click on a clip and then select Replace with After Effects Composition. I then use AE to do color grading, motion effects, and pretty much everything else.
    Once that effort is complete I save it and most things seem to follow back to Premiere on the timeline. I have not rendered anything yet.
    I did notice that my Vignette settings did not follow the render down to Premiere so this got me to thinking…
    Is this an ok workflow or am I going to lose quality or some functionality (like vignettes) by doing this?
    Once a sequence of clips is all edited, etc…then just rendering from the Premiere timeline …or do I really need to do the rendering in AE?
    Todd Kopriva replied 15 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • Michael Frantz
    June 1, 2011 at 8:28 pm
    Let me clarify a little and then I would love to hear more. What I am doing at this point is I lay out a series of clips into a sequence and do all of the editing/cutting/sizing, clipping and such first. Once the sequence is what I want and flows through for the movie …then I take the clips and work along the timeline and push up to AE to grade, etc…
    I am not rendering anything at all up to this point. Should I render first and then go up to AE? Or continue working the way I am and then render the clip while its up in AE and replace the source on my timeline?
    Or can I just work in AE do all of the effects I need and save it…it udpate’s in premiere too (or seems too with that one exception) and then do just one render at the end?
    I hope that explains better? Thanks for your time on this.
  • Michael Frantz
    June 1, 2011 at 8:55 pm
    Ahh yeah I spent the bucks on this software specifically to take advantage of the Adobe workflow and ability to share between the programs. I just want to make sure I am on the right track with my workflow.
    It is VERY nice to be able to edit in premiere and then push up to AE do all of the special effects needed, color grade with Color Finesse, and use Magic Bullet for tweaks and such while not once having to render anything until the very end…
    If this works as it seems it should my editing workflow time is literally cut in 1/4 of the old Sony Vegas to AE days…
  • Shawn Miller
    June 2, 2011 at 12:30 am
    Hey Michael,
    This is my preferred way of working. I cut in Premiere Pro and shuffle to and from AE via the Dynamic Link. I only render when absolutely needed and/or at the very end. But Dave is correct, you can open entire PP projects in AE.
    Shawn
  • Michael Frantz
    June 2, 2011 at 12:35 am
    Ahh thanks much.
  • Todd Kopriva
    June 2, 2011 at 2:25 am
    Here’s an outline of the ways that you can move data between After Effects and Premiere Pro.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Robert Ober
    July 31, 2011 at 7:47 pm
    Is there a link missing?
    Robert
  • Todd Kopriva
    July 31, 2011 at 9:15 pm
    Oops. I don’t know what happened there. Here’s the link.
