Activity Forums Adobe After Effects Question about pre-comp
  • Question about pre-comp
    Posted by Walkingduck on April 24, 2005 at 9:05 am
    Hello folks,
    I’m not sure if this would be newbie question, but the fact is I don’t know.
    My question is..
    I have one layer that I added Shine effect in a pre-comp and I drop that pre-comp into a new comp. I see shine effect cuts off at the end of pre-comp’s size when I scale down the pre-comp . So, I’d go back to pre-comp and make the composition size bigger so that the shine effect won’t get cut off in the new comp, but is there a way that I can just make it not cut off without making my pre-comp’s size huge? once you make your pre-comp bigger than 4000×4000, AE seems to be a lot slower.
    Hope this make sense to you.
    Thank you.
    Chris Smith replied 21 years, 4 months ago 5 Members · 4 Replies
  • Stylz
    April 24, 2005 at 9:14 am
    Effect>Image control>grow bounds.
  • Ace Billet
    April 24, 2005 at 3:13 pm
    Try to select Collapse Transformation (the little ‘Sun’ icon) , next to the layer name.
    cheers
    ace
    Intel Inside, the world’s most popular warning label.
  • Filip Vandueren
    April 24, 2005 at 5:41 pm
    If you just use grow bounds, you’ll get the same performance-issues: it needs to set up a huge 4000×4000 buffer.
    There’s actually a movie/tutorial on the Trapcode site that deals with the problem and suggest several work-arounds, each with their own advantages and disadvantges:
    Shine cutoff (How to avoid having the rays cut off)
    perhaps in your case the adjustment-layer approach could work.
    greets,
    Filip
  • Chris Smith
    April 25, 2005 at 5:25 pm
    Why not put shine on the precomp rather than inside of it?
    Chris Smith
    https://www.sugarfilmproduction.com
