Activity Forums Adobe Premiere Pro Question about multi-cam in Premiere
  • Question about multi-cam in Premiere
    Posted by Daniel Herter on October 17, 2013 at 11:32 am
    Hi guys,
    I have a question about multicamming in Premiere Pro CC:
    We have shot an event with 4 different camera’s and I want to use the multicam function to edit this. I have just seen several tutorials, and everywhere they say that you have to mark the clips by opening them from the project window, then put them in one bin and select them so you can create the multicam sequence.
    My problem is:
    Someone already did the tough job and put all the clips sync, but he did this by putting them all in a sequence in layers above eachother. Is there anyway to import this to a multicam sequence without having to find al the clips first, put them in a bin, marking them and create the multicam sequence?
    Hope someone can help me with this!
    Cheers,
    Daniel
    Paul Neumann replied 12 years, 11 months ago 3 Members · 2 Replies
  • Bob Pierce
    October 17, 2013 at 1:40 pm
    You can use markers for syncing up your mulitcam clip. Simply put the CTI over the clips in the timeline, put a clip marker on each clip by selecting the clip individually. You may need to go into Keyboard layout to assign a key for “Clip Marker” (rather than timeline marker). Then select marker as your sync point when creating the mulitcam clip.
    Good luck,
    Bob
    Director of Photography • Editor
    http://www.lightstreamassociates.com
  • Paul Neumann
    October 17, 2013 at 3:00 pm
    Select all the video clips and nest them. Then enable this nested clip for multicam. At this point I usually make a new timeline from this timeline and cut the multicam there.
