Activity › Forums › DSLR Video › Question about Mpegstream – DSLR workflow in Final Cut Pro.
Posted by Tarek Gamaleldin on August 25, 2011 at 2:14 pmHello,
I wonder if anyone can help?
If i use Mpeg Stream clip to convert my DSLR clips to ProRes 422 Proxy, would there be a way in FCP to conform my Sequence to ProRes 422 (the way you can if you use Log and Transfer)?
or do i need to set Mpeg Stream to ProRes 422 from the start?Thanks!!!
Brent Dunn replied 15 years ago 4 Members · 6 Replies -
Phil Balsdon
August 25, 2011 at 9:22 pmHave you considered using the Canon EOS Movie plugin to Log and Transfer the footage into FCP. This method converts camera data embedded in the footage to timecode and would make any re-connection to higher ProRes later much simpler as you’ll get matching timecode.
Do a search for Shane’s HDSLR Workflow tutorial on this site.
Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
https://philming.com.au
https://www.steadi-onfilms.com.au/ -
Brent Dunn
August 26, 2011 at 6:44 pmYou don’t need to use MPEG Streamclip. Just use the log and transfer. It conforms to ProRes. Just drop your clip on the timeline and it sets up your timeline automatically to ProRes for editing.
Brent Dunn
Owner / Director / Editor
DunnRight Films
DunnRight Video.com
Video Marketing Toolbox.netSony EX-1,
Canon 5D Mark II
Canon 7D
Mac Pro Tower, Quad Core,
with Final Cut StudioHP i7 Quad laptop
Adobe CS-5 Production Suite -
Shane Ross
August 29, 2011 at 7:27 amThis is the tutorial….
Tapeless Workflow for FCP 7 Tutorial
Shane
Read my blog, Little Frog in High Def -
Tarek Gamaleldin
August 30, 2011 at 6:17 pmThanks for the responses!
We’ve already used MPEG Steramclip to generate about 100 hours of ProRes Proxy. Would we be better off forgetting about that and redoing it all in Log and Transfer?
Thanks again.
Shane Ross
August 30, 2011 at 7:40 pm[Tarek Gamaleldin] “Would we be better off forgetting about that and redoing it all in Log and Transfer?”
If you plan on going with an online/offline workflow…yes. Doing it with MPEG STREAMCLIP (offline/online workflow) is VERY problematic. If you want smooth offline/online, gotta to it entirely in FCP.
Shane
Brent Dunn
August 31, 2011 at 7:54 pmNo, you’re fine with the footage already transcoded, but you’ll be better off and it may be a bit faster using log and transfer. Final Cut is never great or time effecient in transcoding. Premier is so much faster.
Brent Dunn
DunnRight Films
DunnRight Video.com
Canon 5D Mark II
Canon 7D
