Question about mp4 file (corrupt sd card)
Shinra Bansho replied 8 years, 3 months ago 4 Members · 13 Replies
Derek Charles
June 23, 2018 at 12:29 amI’m in Catalyst browse I have the export settings the same everything other than wondering why I cant have a “no crop” option it only allows me to choose letterbox, cinemascope, or center crop.
Derek Charles
June 23, 2018 at 1:00 amAlso, Along with the crop issue, there’s no option to render the same 24p – it only has options for 30 and 60p
Shinra Bansho
June 23, 2018 at 1:49 pmI don’t own a7sii and had never worked on 24p footage, so I downloaded a sample a7sii 4K 24p footage from VIMEO, and loaded the file onto Catalyst Browse.
In the transcode setting, I see 24p (& 23.976p) along with 30p, 50p and 60p for 3840 x 2160 resolution. I also see “no crop” option as below.
https://www.dropbox.com/s/me45niore2dd71u/Transcode%20%20-%20Framerate.jpg?dl=0
https://www.dropbox.com/s/ibao7c32geb86ft/Transcode%20to%20Crop%20Type.jpg?dl=0Are you sure that your recovered footage has the same resolution and the frame rate as those of the original footage? Check the file with MediaInfo.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
