Activity Forums Adobe After Effects Question About Interpolation Key frames
  • Question About Interpolation Key frames
    Posted by John Jackowiak on January 19, 2007 at 4:18 pm
    I have been working with AE 7, and I’m having a hard time dealin with interpolation key frames to smooth out movements in time. IN AE 6.5 you could just check or uncheck the boxes under the position keyframes to adjust this. But in AE 7, the only way I can do it is to select them and then go through a menu at the top, which is time consuming. Is there a shortcut?
    -stev=o replied 19 years, 8 months ago 2 Members · 1 Reply
  • -stev=o Create COW Profile Image
    -stev=o
    January 19, 2007 at 8:25 pm
    Hold down “ctrl” and click on the keyframe.
    -stev=o
