Activity Forums Blackmagic Design question about hdmi output of decklink extreme
  • question about hdmi output of decklink extreme
    Posted by Koufopoulos Hector on September 19, 2008 at 10:46 am
    I am thinking of bying a decklink extreme card for my macpro / fcp setup.Also another 24″ lcd display for monitoring
    My question is this: Do i need hdlink for monitoring or the hdmi output of decklink extreme is enough for monitoring in hdmi- input monitors
    Thanks in advance
    Hector Koufopoulos
    Patrick Britton replied 17 years, 4 months ago 3 Members · 2 Replies
  • Callum Mclay
    September 19, 2008 at 6:13 pm
    Hi Hector
    The HDMI output of the HD Extreme 2 is a fully fledged HDMI output, for the full information please check the technical specification here:
    https://www.blackmagic-design.com/products/hd/techspecs/
    The HDLink is able to convert the SDI output of the HD Extreme 2 into a DVI or HDMI output (using an adapter) for use with computer LCD screens. If your screen already excepts HDMI input, then you can just go directly out of the Decklink card via HDMI into your screen, as long as it supports the appropriate resolutions (1080i, 720p etc)
    So to connect to a HDMI monitor or TV is a great solution, especially to use a cheap HDTV as a HD Monitoring solution!
    Callum McLay
    Technical Support Consultant
    Blackmagic Design EMEA
  • Patrick Britton
    April 17, 2009 at 6:03 am
    To clarify, can the HD Extreme 2 (or 3) do true (FULL HD) 1080p over hdmi?
    thanks.
