Activity Forums Apple Final Cut Pro Legacy question about FCP changing sequence settings
  • question about FCP changing sequence settings
    Posted by Andre Luis on April 28, 2010 at 3:00 pm
    Hi folks,
    I’m having some issues here: I always edit content shot in interlaced HD. But when I import these content to FCP timeline and the windows asking “Change sequence settings to match the clip settings” appear, and I click “yes”, it recognizes the content as being progressive video, instead of interlaced.
    Is it normal to FCP to miss the real clip settings?
    The problem with it is I don’t always know if the content was shot with upper or lower interlaced.
    Hope you can help me, and sorry for the poor english.
    Michael Gissing replied 16 years, 4 months ago 3 Members · 7 Replies
  • 7 Replies
  • Aaron Neitz
    April 28, 2010 at 3:08 pm
    You’re in PAL I assume.
    PAL 1080/25, even though it IS progressive, is treated by FCP and broadcast systems as interlaced, upper field dominant.
  • Andre Luis
    April 28, 2010 at 3:23 pm
    Hi Aaron, thanks for your reply.
    Actually, it is NTSC, 29.97 fps.
    Still can’t figure out why does it happen.
    Here’s some snapshots from the setting window and the video preview, maybe it can illustrate better what is going on:
  • Aaron Neitz
    April 28, 2010 at 7:59 pm
    I see. what happens if you just make a empty sequence that matches your footage and drop clips into that? FCP must be mistaking some metadata.
    If I’m reading you correctly – you probably want these settings. It would also help to know what camera you’re shooting and in which mode.
  • Aaron Neitz
    April 28, 2010 at 8:00 pm
  • Andre Luis
    April 28, 2010 at 8:08 pm
    what is really happening is that FCP understands these footages were shot in progressive video, but they were shot in interlaced video. Even when I right-click the footage in the FC browser and go to “format”, it says “field dominance: none”
    Is there some app for mac (outside FCP) which tells you the details on a .mov file?
  • Andre Luis
    April 28, 2010 at 8:13 pm
    Aaron, if I make the setup as you put on the picture, when I put the footage in the timeline FCP will ask if I want to match the video settings. I click “no” and it’ll ask for a preview render. But the video is no longer interlaced in the preview window (like the picture I posted above).
  • Michael Gissing
    April 28, 2010 at 10:15 pm
    What codec/camera did you shoot with and how is it getting into FCP.It may be as simple as setting the flag on each clip as upper. Try changing the field settings to upper on one clip and dragging it into a new sequence to see if the render bar goes away and the footage plays nicely.
    HD 1080 is often in an interlaced form, even if the content was shot progressive. This is commonly referred to as psf. If you are delivering to a broadcaster they will be expecting an interlaced master.
    Interlaced HD is upper with all frame rates.
