Activity Forums Adobe Photoshop Question about changing text in Photoshop?
  • Question about changing text in Photoshop?
    Posted by Eric Pautsch on January 13, 2006 at 6:23 am
    I have several photoshop file with text that I need translated to different languages.
    Since the translator probably wont have photoshop can I have them translate into a text file then copy that translation into my original photshop file assuming I have installed the languages into my application?
    Thanks Eric
    Jayse replied 20 years, 7 months ago 3 Members · 2 Replies
  • Richard Harrington
    January 13, 2006 at 12:20 pm
    Yes… if you have teh correct fonts loaded and the ones you’ve chosen support that character set…
    I’d be sure to get a hard copy from the translator so you can compare
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
  • Jayse
    January 18, 2006 at 3:06 am
    Rich is right – make sure to get it proofed by the translator after it’s in PS. Things get a little weird in my experience even with the same fonts – especially if going in and out of MS Word.
    Good luck and good proofing,
    // jayse
    Ultimate After Effects Video Training CDs
    Free Photoshop CS Video Tutorials
