Activity › Forums › Apple Final Cut Pro Legacy › Question about bit depth and Quicktime files
Posted by Chris Wiseman on June 13, 2006 at 3:55 pmAre QTs 8bit, and is it possible to really create a 10 bit QT? Thanks in advance.
Marco Solorio replied 20 years, 3 months ago 3 Members · 3 Replies -
Jerry Hofmann
June 13, 2006 at 4:15 pmJust remember QT is nothing more than a container for ANY bit depth movie… it’s not determined by QT, but rather the codec involved.
Jerry
Marco Solorio
June 14, 2006 at 1:32 amExactly as Jerry described. To add, you need to make sure you’re working in a bit-depth higher than 8-bit to begin with, otherwise you’re just wasting file size space. For instance, in AE, you’ll need to make sure your comp is set to 16-bit or higher. In FCP, your captured media needs to have been captured in 10-bit and are working in a 10-bit timeline.
Both the standard Apple 10-bit uncompressed codec and BMD 10-bit uncompressed codec will work.
Marco Solorio | OneRiver Media
