Activity Forums Apple Final Cut Pro Legacy Question about archiving
  • Question about archiving
    Posted by Joan Solsona on February 1, 2010 at 11:41 am
    Hi there.
    I have most of my master movies in ProRes HQ, since i read that ProRes i a Lossless codec, i edit, grade and do compositing using the same codec. The Master clip that i export is ProRes too. So, my question is, should i also export an “uncompressed 4:2:2 10 bit” movie or it’s useless because the ProRes movie is High Quality enough?
    Thanks in advance,
    Joan.
    Joan Solsona replied 16 years, 7 months ago 2 Members · 4 Replies
  • Rafael Amador
    February 1, 2010 at 11:59 am
    Hi Joan,
    Although Prores is not fully losseless, it can undergoes a few re-compressions without degradation.
    You don’t have to worry and can skip 10b Unc.
    I only use 10b Unc, some times, for very short things that, after Color, I send to to Motion and back to FC, and to do that i ill start to use Prores 444 as soon as I install FC7.
    Cheers,
    Rafael
    http://www.nagavideo.com
  • Joan Solsona
    February 1, 2010 at 12:30 pm
    So then i guess that the right way to do would be stay ProRes all the way and use ProRes 4444 only for mastering or transferring to AE, for example, right?
  • Rafael Amador
    February 1, 2010 at 1:11 pm
    The only real lossless process is when we export to 444 Uncompress.
    When we export to 10b Uncompress,(422) we lost half of the color.
    Prores 444 introduce a bit of compression, but avoid the color down-sampling and this is more important to keep the quality of the stuff.
    If you add the difference in files size, there is no much doubt.
    rafael
  • Joan Solsona
    February 1, 2010 at 2:38 pm
    Wow , that was exactly the information that i needed. thanks a lot, Rafael.
    Joan.
