Activity › Forums › Adobe After Effects › question about ambient light
Posted by Nitai Lev-oren on December 6, 2018 at 10:34 pmwhy ambient light doesn’t have position parameter?
I have a problem moving it on 3d space.Todd Perchert replied 7 years, 8 months ago 4 Members · 6 Replies -
Nitai Lev-oren
December 7, 2018 at 7:28 amSorry for the newbee questions:
So it is the same intensity in the frame?
And when do you use it? As a fill light? -
Max Haller
December 7, 2018 at 3:32 pmAmbient light can be thought of like daylight if you’re outside. It just increases the amount of light in the over all scene. So you would generally use it to make the whole scene brighter and use spot or point lights to light specific areas of the scene/ cast shadows. Those type of lights have position and rotation values like you’d expect.
Nitai Lev-oren
December 7, 2018 at 4:17 pmOk what is the difference between spot vs parallel light?
Todd Perchert
December 13, 2018 at 3:33 pmThis might help you understand lighting better in AE.
https://www.lifewire.com/how-to-use-lights-after-effects-4117116
