Activity › Forums › Adobe After Effects › question about after effects
Posted by Jonathan Chon on December 23, 2013 at 8:12 amI have after effects CC. When ever I select an effect and drag it onto the clip, it would just play the effect over a black screen. How do I play the effect with the clip at the same time? Thanks in advance.
Brandon Podell replied 12 years, 9 months ago 3 Members · 3 Replies -
Todd Kopriva
December 23, 2013 at 7:29 pmPlease give much more detail about what you’re trying to do, including which specific effect you’re trying to use.
Start here to learn After Effects:
https://adobe.ly/AE_basics———————————————————————————————————
After Effects team blog
Jonathan Chon
December 24, 2013 at 2:49 amOk, so I drag my video clip into project and then I create a composition of that clip in the timeline. Then I drag particle world onto the clip. Particle world would play over a black screen and you see a grid. How do I get particle world to play on the actual clip?
Brandon Podell
December 25, 2013 at 6:30 amApply the Particle World effect to a solid (Layer –> New –> Solid). Do not apply this effect to the clip itself. Add the solid with the Particle World effect to the layer above your clip.
If you already applied the Particle World effect to your clip, then cut and paste the effect from your clip to the new solid.
Like BPodell Productions on Facebook: http://www.facebook.com/BPodellProductions
View my Film Portfolio: http://www.brandonpodell.com
