Activity Forums VEGAS Pro Question
  • Question
    Posted by Cdmanproductions on May 14, 2006 at 12:03 pm
    ill try to explain what i want to do the best that i can. well here goes. i want to be able to cover lets say a logo on the video. like lets say i capture something off the tv and there is a logo on the bottom right of the screen. i want to either be able to either cover or cut out that part of each frame. ive seen a few videos that it has been done to and basiclly they had cut that part out of each of the frames and bleneded the empty box with the surounding colors. i hope i have explained this so you will be able to understand it. thanks in advance.
    Gary Kleiner replied 20 years, 3 months ago 2 Members · 6 Replies
  • Gary Kleiner
    May 14, 2006 at 3:58 pm
    I think I read somewhere that this is software designed to do this.
    Anyway, in Vegas, my approach would be to put two versions of the video on two tracks. The bottom one unaltered, and the top one with a cookie cutter and blur applied to the offending area.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Cdmanproductions
    May 14, 2006 at 11:04 pm
    ok, im using the cookie cutter but i cant seem to get the cutout part wide enough with out making it way to tall. and it ends up covvering way more of the screen then i want it to. so bascilly how do i make it wider with out making the cutout taller. thanks
  • Gary Kleiner
    May 14, 2006 at 11:44 pm
    What shape are you using? I am thinking that the circle would serve you best here.
    Gary Kleiner
  • Cdmanproductions
    May 14, 2006 at 11:56 pm
    rectangle, thats what the shape of what i cut out is.
  • Cdmanproductions
    May 15, 2006 at 3:15 am
    ok i figured out how to cut the size i want but now i tried all the blur video effects and none of them seem to do what i want. is there a diffrent effect that will make the surrounding colors blend in the part of the frames that are cut out. thanks
  • Gary Kleiner
    May 15, 2006 at 4:50 am
    Mosaic might be worth a shot.
    Gary Kleiner
