Activity Forums Adobe After Effects Expressions Query pixel bounds of text layer
  • Query pixel bounds of text layer
    Posted by Mo Dejong on October 17, 2008 at 9:58 pm
    // Round down to the nearest integer value
    function round_down(n) {
      var floor = Math.floor(n);
      if (n == floor) {
        return n; // already rounded down
      var window = 0.01;
      if (Math.abs(n - floor) < window) {
        return floor; // very close to floor
      var ceil = Math.ceil(n);
      if (Math.abs(ceil - n) < window) {
        return ceil; // very close to ceil
      return floor;
    // Round up to the nearest integer value
    function round_up(n) {
      if (n == ceil) {
        return n; // already rounded up
      var window = 0.01;
      return ceil;
    // Given a layer, return an array contiaing the [x, y, width, height]
    // coordinates of the bounding box for the layer. The coord values
    // are rounded to whole pixels and are in terms of the comp coordinates.
    // For a text layer, return the actual coordinates of the rendered text.
    function layer_bbox(thisLayer, time) {
      var rect = thisLayer.sourceRectAtTime(time, true);
      // The left value indicates an offset from the layer position
      // to the left most position where the layer is rendered.
      // The width value indicates an offset from the left position
      // to the right most rendered position.
      var left = round_down(rect.left);
      var right = round_up(rect.left + rect.width);
      var width = right - left;
      // The top value is the pixel height above the layer position,
      // rounded down to the nearest pixel.
      var top = round_down(rect.top);
      var bottom = round_up(rect.top + rect.height);
      var height = bottom - top;
      // Convert offsets from layer origin to offsets in terms
      // of comp coordinates.
      var pos = chordLayer.transform.position.value;
      var anchor = chordLayer.transform.anchorPoint.value;
      var origin_x = Math.round(pos[0] - anchor[0]) + left;
      var origin_y = Math.round(pos[1] - anchor[1]) + top;
      return [origin_x, origin_y, width, height];
    thisComp = app.project.activeItem;
    if (thisComp == null) {
      alertStr = "No active comp found";
      alert(alertStr);
    } else {
    //  alertStr = "thisComp.name is \\"" + thisComp.name + "\\"";
    //  alert(alertStr);
      chordLayer = thisComp.layer("Chord");
      var bbox = layer_bbox(chordLayer, 0.0) ;
      var origin_x = bbox[0];
      var origin_y = bbox[1];
      var width = bbox[2];
      var height = bbox[3];
      alertStr = "bbox x,y = " + origin_x + "," + origin_y + "  WxH = " + width + "x" + height;
      alert(alertStr);
    } // end of file scope
    Hello all
    I recently tried to figure out how to get the bounding box of a text layer, that is the
    X,Y and WIDTH and HEIGHT, so that I could put a box around the text. I found the
    Layer.sourceRectAtTime() API, but it took a little code to turn its results into something
    I could use to create a box. The trick was that I wanted X,Y values in terms of pixels in
    the comp, so a little rounding of the coord values was required. I am posting this script
    in case it is helpful to others.
    cheers
    Mo DeJong
    Dennis Cheung replied 14 years, 5 months ago 2 Members · 1 Reply
  • Dennis Cheung
    April 4, 2012 at 8:58 pm
    Hi
    I was digging around for a script like this. Can you or anyone tell me how and where to apply this? It’s a little advanced for me.
