Activity Forums Adobe After Effects Query on outputting to DVD
  • Query on outputting to DVD
    Posted by Daryl Booth on March 28, 2008 at 11:19 pm
    Hi all,
    I am in the process of finishing up a project. I want the end result to go onto a DVD. Thus far I have only usually bother to output as WMV for youtube etc etc.. What is the best output for burning to DVD.
    Also which software do you use/reccommend on using to burn the resulting file onto dvd?
    TIA
    salutations from codemonkey
    Daryl Booth replied 18 years, 5 months ago 2 Members · 2 Replies
  • Darby Edelen
    March 28, 2008 at 11:44 pm
    [Daryl Booth] “What is the best output for burning to DVD.”
    Standard definition DVDs will only accept MPEG-1 or MPEG-2 as a video stream… and MPEG-2 is a much better choice. However, your workflow from AE will vary. You might want to render out lossless from AE to have the highest quality digital master you can, then use a program such as Sorenson Squeeze or Apple’s Compressor to compress the lossless file to MPEG-2. This also leaves you the option of compressing the same master into H.264 or WMV for web distribution.
    That said, you can also render MPEG-2 directly out of AE, but this should only be considered a viable option if you have limited hard drive space or are only rendering DVD menus (which will probably never be distributed in another format). The MPEG-2 encoder that ships with AE is a good one, but it limits your workflow options.
    [Daryl Booth] “Also which software do you use/reccommend on using to burn the resulting file onto dvd? “
    I use DVD Studio Pro, but if you’re talking about WMVs my guess is you’re on a PC. In that case I would recommend looking at some of Sonic’s products: https://www.sonic.com/
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Daryl Booth
    March 29, 2008 at 8:28 am
    Many thanks for the quick reply. I will look into the products you have mentioned.
    Which file type is the best to output from AE for burning to DVD; Quick time/Avi/WMV/MPG2? I am a bit lost with all the varying factors on this subject matter and want to avoid wading through endless pages on the net on compression/cbr/multipass etc etc..
    Many thanks by the way Darby
