Activity Forums Apple Final Cut Pro Legacy queries regarding rendering out from FCP and digitizing
  • queries regarding rendering out from FCP and digitizing
    Posted by Aroonz Arunpg on January 17, 2011 at 5:53 am
    Hi all,
    i know its basics.. but.. few doubts..
    i have a commercial shot on RED. we have the final version as HD 1080i.
    I have requests from the agency for the same to be delivered in DIGIBETA tapes on 4:3, 16:9 and 14:9 ratios..
    How should i prepare the timeline ? should it be 720 * 576 or should it be 1080i ?
    also how can i deal with the aspect ratios ?
    If i render the timeline in 720*576, can someone capture at high quality , mayb in 1080 i ?? am confused..
    Please help me !!!
    Ben Holmes replied 15 years, 8 months ago 2 Members · 1 Reply
  • Ben Holmes
    January 17, 2011 at 3:51 pm
    Use 1080i as your master format (note RED footage is progressive, so it will actually be 1080p).
    When you have to make SD copies, use compressor to do high-quality scaling, or better, use a Kona or Blackmagic output to do a down-res. Both cards can be set to do the crop or letterbox as required.
    There’s too much info here to reply in a single post. If you’re unsure of this, seek professional advice from a post house. Making commercial content from RED footage is not something you should undertake alone if you’re posting these questions – with respect.
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
