Activity Forums Avid Media Composer Qucktime reference set-up level shift
  • Qucktime reference set-up level shift
    Posted by Max Kovalsky on February 5, 2008 at 6:23 pm
    Here’s the workflow that’s causing trouble:
    1. Clip is digitized as 1:1 HD or DNxHD
    2. Clip is copied to Media Composer software-only system
    3. QT reference of the clip is encoded to HD AVC or mpeg2 via MainConcept
    4. Resulting encode has lifted blacks
    We bring the QT back into Avid, look at it on the built-in waveform, and the blacks ARE LIFTED.
    Steps taken to trouble-shoot the issue:
    1. The clip is mixed-down or color-effected (with no change in color)
    2. Clip is exported as QT reference
    3. Clip is re-imported into Avid
    Blacks are FINE.
    BUT…
    If that mixed-down clip is encoded with MainConcept or CinemaCraft, the resulting mpeg has… again, LIFTED blacks. Both MainConcept and Cinemacraft do not lift blacks on AVIs from Premiere or QTs from FCP, so the issue is not with the encoders.
    However, if that same clip is encoded with ProCoder, blacks are FINE. Unfortunately, we can’t use ProCoder because it does not support AVC very well.
    QT version is 7.2 on both the digitizing Avid and the software-only one.
    MC version is 2.7.5 on the digitizing Avid and 2.6 on the software-only one.
    Michael Phillips replied 18 years, 7 months ago 3 Members · 3 Replies
  • Bouke Vahl
    February 5, 2008 at 8:29 pm
    There is something called 601/709 levels.
    You probably export as that. Although Qt ref, Avid nowadays can also output RGB levels that most encoders expect.
    Some encoders can be told that input is in fact NOT rgb, but (at least with Cinemacraft), this only works well with half Avid’s codecs.
    Test, test, test is my only advice.
    Bouke
    http://www.videoToolShed.com
    smart tools for video pro’s
  • Max Kovalsky
    February 5, 2008 at 9:08 pm
    Thanks. I feel like I ran out of tests. Tried both 601 and RGB. RGB looks lifted even in the QT player.
    Max
    Author
    New York
    Area4.tv
  • Michael Phillips
    February 6, 2008 at 2:22 am
    Look for settngs in the encoder that indicate sources are 16-235 or not. if exported as 601/709, check that setting.
    Michael
    Michael Phillips
