Activity › Forums › Apple Final Cut Pro Legacy › Qucktime mpg4 and pixel aspect ratio
  • Qucktime mpg4 and pixel aspect ratio
    Posted by Sharilynn on November 13, 2005 at 6:14 am
    Hello,
    I’ve exported a couple of FCP clips to QT Mpg4 format to use in a presentation by eZedia (similar to Powerpoint, in some ways). I imported the clips into a suitable frame, but have since found that there is distortion, as I changed the frame. I need to adjust it back again. Should the ratio be 720 x 480? That seems a bit much.
    Shari
    Sharilynn replied 20 years, 10 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    November 13, 2005 at 2:59 pm
    “Changed the frame”… what are you referring to? changing the frame in dZedia? or?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jeremy Garchow
    November 13, 2005 at 5:31 pm
    Are you viewing this material on a crt monitor? If so you will have to change the pixel aspect ratio, (square to non square).
    What program did you use to encode the mp4s? What recipe did you use? What’s the frame size?
  • Sharilynn
    November 16, 2005 at 8:25 am
    Sorry to respond so slowly – it’s been a bit hectic on this end. I did adjust the frame that held the video to be at a 4:3 ratio, and solved the problem.
    Thanks for your time, and your concern. I’m sure I’ll need help again sometime in the future, and I appreciate you being here.
    Shari
