Quartz Composer – Motion Plugin
Hello.
I want to create simple plugin, which creates flashes on the screan and
read light coordinates. I want to work this plugin in Aplle Motion. Is
there any way to do that plugin in quartz composer, which works like
that:
– user in Motion can select how many flashes he wants to put on the
screen,
– user can read light coordinates when he pushes the button,
– all plugin have to work in separate window [not only in inspector in Motion].
Can u write me is quartz compose has that components to do that kind of
plugin? And is the fxfaxtory can convert it to Motion?
Or maybe i should do it different way?Thanks for your answer!
