Quantize to Frames
Posted by Gary & yvonne on January 11, 2006 at 10:38 amI still can’t figure out if Quantize to Frames is On or Off….I’m looking at it under options and nothing changes on the icon when I click on it. How do you tell wheather it’s on or off?……………Thanks, Gary
Chris Young replied 20 years, 8 months ago 8 Members · 10 Replies -
Gary Kleiner
January 11, 2006 at 2:16 pmZoom in so you are only looking at a few frames. If QTF is on, then you can easily see the edges of events jump to the frame boundaries as you move or trim events. If it’s off, then you will be able to move them freely with no snapping.
Gary Kleiner
Learn Vegas and DVD Architect
http://www.VegasTrainingAndTools.com
Terry Esslinger
January 11, 2006 at 9:53 pmGary,
I think Gary is asking how can you tell by looking at the button if QTF is enabled or not. -
Gary Kleiner
January 12, 2006 at 2:35 am[Terry Esslinger] “how can you tell by looking at the button if QTF is enabled or not.”
You can’t.
Gary Kleiner
Stephen Mann
January 12, 2006 at 4:14 amYou sure?? The QTF button on my screen is a toggle just like the snap, crossfades and Ripple buttons.
Edward Troxel
January 12, 2006 at 4:16 pm -
Stephen Mann
January 13, 2006 at 12:31 amThen, I am missing something because the Options Menu has a checkmark when Quantize is selected, and the toolbar clearly highlights the selected buttons.
Steve Mann
Edward Troxel
January 13, 2006 at 2:21 am -
Terje A. bergesen
January 13, 2006 at 6:12 amLooking at Vegas 6, there is no way to see on the menu if QTF is on or not. There is an image, no check box.
Terje A. Bergesen -
Gary Alan
January 13, 2006 at 6:56 amI purposely put the Quantize button on the toolbar (customize) so I can see it. It will easily show a lighter gray background when it is on. Like the button is depressed with edge shading. I got burned once with it off during a video project. When off, it can create many 2-3 frame dissolves where you want cuts.
Chris Young
January 13, 2006 at 10:10 amGeez! Sometimes it takes someone to slap one around the face to see the obvious. Gary your solution is so simple I’m kicking myself for not thinking of it before. I’ve used customise toolbar before but never thought to look there for a quantize selection button! This sub frame audio editing thing has been a problem for many editors coming to Vegas when they have been used to editing on systems that don’t have that ability to go sub frame. Very easy to leave it unchecked and create problems. I had one editor do an entire one hour show with all the video edits all over the place between frames! An absolute No! No! for broadcast. Thanks for the heads up.
Chris Young
CYV Productions
Sydney
