Activity Forums VEGAS Pro “Quantize To Frame” Bug ?
  • Don Donatello
    May 12, 2005 at 1:57 pm
    i can’t see quantize problem from clip provided. you need to zoom into TL a little more to see if quantize is working.
  • Gilles Pialat
    May 12, 2005 at 2:38 pm
    The red marks indicate that the clip is unquantized.
    If i zoom in the TL, the end of the clip does not correspond with a project frame.
    This happen only with clip edit & TL scroll.
    Not very annoying, but good to know.
  • Don Donatello
    May 12, 2005 at 8:56 pm
    i’m on the road so i don’t have V6 on this laptop..
    in V5 i don’t see any red marks when i slip shots ( with quantize off – then turn back ON after slipping so frame lines are not lined up) i then move the clip down/up TL and still i don’tget a red line …
    well anyway you get the clip back to proper place -turn off quantize ..place curser in TL at TC then zoom into TL then slip ( hold ALT while you right click drag video clip ) the shot till the small picture lines up with the curser at TC – once you line them up then turn quantize ON
  • Gilles Pialat
    May 12, 2005 at 9:01 pm
    Have you enabled “Show Unquantized Event Start & End” in internal preference ?
