Activity › Forums › Compression Techniques › Quality settings: 1080 to standard DVD
  • Quality settings: 1080 to standard DVD
    Posted by Matt Surf on January 2, 2012 at 3:54 pm
    Hi there,
    I recently shot a massage film against a white background and I’m having difficulties compressing the footage for use on a DVD.
    The film was shot in full HD using a Canon EOS 550D then compressed using Pro Res and edited out through FCP7. So far so good.
    However, when I go through the usual Compressor settings for DVD Best Quality 90 minutes I get jagged edges on the lips of the subject when she talks plus other jagged issues.
    So, I did a bit of surfing and created a new Compressor setting with Frame Controls set to Resize Filters: Better / Output Fields: Same as Source and Deinterlace: Better and Adaptive Details is ticked.
    However, this option is creating faint black/grey horizontal lines across the white background of my encoded film.
    Any help so I can get the best settings to stop either of these happening would be greatly appreciated. For info, both versions have been used on a Sony Blu Ray player on a HD Ready LCD TV which I assumes is trying to upscale the quality.
    I also tried using Larry Jordan’s settings and converted into Pro Res 422 HQ first but this just created a version where half the screen was black and the other section was weird pinks and green flashes (bizarre).
    Thanks in advance for any help
    Matt
    Matt Surf replied 14 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
