Activity Forums Apple Final Cut Pro Legacy Quality question seeking answer please
  • Quality question seeking answer please
    Posted by Will Keir on March 10, 2006 at 4:44 am
    My question is basically this. I was rushed to capture a mini-DV tape before I handed it off to my partner, who lives 8 hours away. So I didn’t get the chance to individually capture the takes I wanted.
    Instead I captured the whole tape. Now I have a huge, long file which I don’t want in it’s entirety. Instead I want to pull a few takes that worked and trash the rest of the file. And let’s just say I have several tapes like this. Now… all my human error’s aside, is there a way to create smaller files from the main one without losing a bit of quality?
    That’s why I’m asking the questions; I am not going to do this If I lose quality when I take the smaller clips and export them as their own files. I’m also not sure if this method will change any video options. I assume if I have the file logged, anamorphically, then I edit on an anamophic timeline and export it with the built it properties then there should be no video changes.
    The main concern I have is quality, will I lose quality doing this?
    Thanks for any help,
    Will Keir
    Will Keir replied 20 years, 6 months ago 3 Members · 3 Replies
  • Matthew Brunn
    March 10, 2006 at 4:55 am
    No quality loss.
    Hope this helps-
    Matthew
    Quad 2.5 G5
    OSX 10.4.X
    Ram 4GB
    FCP 4.5/AE 6.5/DVDSP3
  • Bret Williams
    March 10, 2006 at 5:21 am
    You can actually just put your selects into a timeline and media manage it, telling media manager to use the original clips, and delete the unused portion. No need to even copy the clips.
    But if it’s just a couple clips, it’s just about as fast to export them as FCP movies, self contained. Don’t check the box labeled “recompress.” Duh.
  • Will Keir
    March 10, 2006 at 6:12 am
    Thanks Matt, good to know.
    Bret,
    Not really too sure what you were trying to say, would you mind being more specific?
    Thanks for the posts guys,
    Will Keir
