Activity › Forums › Apple Final Cut Pro Legacy › Quality problems with importing a picture/watermark into Final Cut Pro
Posted by Mike Elling on November 4, 2008 at 5:27 amHi!
I am editing a video where I need to import a company logo as a watermark on the lower right hand side. I have a png file and it looks really big & clear in photoshop, but when I import it into FCP and reduce the size, the quality looks awful. I think there must be some specific rules as to how to do this, but I don’t know them. Do I save it as a jpeg? A tiff? Can someone help?
Thank you so much!!!
Chris Poisson replied 17 years, 9 months ago 6 Members · 7 Replies -
Shane Ross
November 4, 2008 at 5:56 amWhat are the sequence settings? Settings of the footage you are working with? If it is DV, then yeah, it will look a lot worse, due to the DV compression.
Switching the sequence settings to DV50 might help a bit.
Shane
Read my blog, Little Frog in High Def -
Mike Elling
November 4, 2008 at 7:30 amHey Shane,
Thanks for answering my post…
The settings I’ve been using are just the standard DV/DVC PRO-NTSC settings on Final Cut Pro 5. Do you mean I have to re-import everything? Is there ANY way to do this with the current settings?
Thanks -
David Roth weiss
November 4, 2008 at 7:51 am[Mike Elling] “Do you mean I have to re-import everything? Is there ANY way to do this with the current settings?”
Shane was suggesting that you change the quicktime compressor in the sequence settings to DV50. Then re-render. That essentially changes the codec, and since DV50 is 4:2:2 color space it yields superior results over the 4:1:1 color space of DV when compressing graphics and text.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Mike Elling
November 4, 2008 at 9:39 amThanks guys for all of your help & attention. I am worried now because I just did exactly what you said, but I’m not sure it fully solved my problem. It still looks a tiny bit grainy, plus even the graphics I generated within FCP look a smidge grainy too (the lower 3rd looks not so good…) I’ve never worked with graphics on this kind of level, so I do not know how to troublehshoot this. Who would’ve thought that such a little image in the lower right hand corner would cause me so many problems? Not sure the next step. Helpline?
Rafael Amador
November 4, 2008 at 12:59 pmYou need to set the FCs canvas at 100% and render to see how really looks.
Rafael -
Jeremy Garchow
November 4, 2008 at 2:36 pmWhat Rafael says, and better yet you should add a proper monitor into that mix. You will never know how your timeline really looks unless you play it out to a monitor.
Jeremy
Chris Poisson
November 4, 2008 at 3:25 pmIn addition to changing your compressor settings as suggested, you might try a tiff file. Set an alpha channel in it though, or just import a Photoshop file with layers, and copy and past the logo into your sequence.
Have a wonderful day.
