Activity Forums VEGAS Pro Quality Problem?
  • Quality Problem?
    Posted by Tristin Silkias on July 1, 2009 at 2:54 am
    When I have the preview of my video in draft or, preview mode? the lowest 2 qualities is my point. My video appears. When the quality is in the top to choices (x and best) I can’t see the video. I had a title over my video, and I decided to crank the quality up and then the video stopped appearing, but the title stayed there. The original size of the video was 1024×768 and I was rendering it in 1280×720 HD for youtube. I set the project properties to have that resolution (1280×720) Anyway, my point is, I need this problem fixed so I can make the video. If you need anymore information or have any ideas on how to fix this, respond ASAP!!!!!
    John Rofrano replied 17 years, 2 months ago 3 Members · 5 Replies
  • Tristin Silkias
    July 1, 2009 at 6:41 am
    yea info is on original post, I just should’ve used this subject title 🙂
  • John Rofrano
    July 1, 2009 at 12:32 pm
    What codec does the video use? If it’s FRAPS video, you may have to re-encode it to a codec that Vegas can support. Try huffYUV or Lagarith as two lossless codecs that should edit easily and retain quality.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Philip Scoggins
    July 1, 2009 at 4:30 pm
    I’ve been having the same problem. I tried changing my preview quality down to draft and the lost/muted track appeared in my preview. I then changed the quality back to good and it stayed.
    Is Vegas 9 any more stable than 8.1?
  • Tristin Silkias
    July 1, 2009 at 5:31 pm
    I use the X-Vid Codec that I use with the Source recorder for Garrys Mod (actually, any steam game. Steam is a gaming client) I can try another codec 🙂 If I have any problems I’ll let you know.
  • John Rofrano
    July 2, 2009 at 7:56 pm
    Yea, Vegas does not play well with DivX and XviD. Try using a different codec.
    ~jr
