Activity Forums Apple Final Cut Pro Legacy Quality of ripped DVD file
  • Quality of ripped DVD file
    Posted by Atticus Brady on November 27, 2010 at 3:47 am
    Happy Thanksgiving everyone!
    I recently ripped a DVD of an old movie with the Handbrake software and then ran the resulting m4v file through Compressor. I applied a Quicktime Apple Pro Res 422 HQ setting and came out with a Pro Res file which I then imported into Final Cut. When I play the clip in the Viewer it goes out of sync. When I cut a piece of it into the sequence, it retains sync but the image is a bit pixelated and jerky, not very good quality. Is there some other setting I can apply to make the import better quality? FYI, the m4v file created from the original rip plays perfectly well in iTunes.
    Thanks for any help!
    Atticus
    Final Cut Studio 3
    Mac Pro 8-core
    12 gigs RAM
    2 x 2.26 Ghz
    ATI Radeon HD 4870
    Chris Tompkins replied 15 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • Zane Barker
    November 27, 2010 at 4:18 am
    Your converting the file 2x before even starting to edit in FC. That’s no the best workflow.
    Questions like yours about DVD footage come up all the time. A search of the forums will yield plenty of info.
    All I’ll say is mpegstreamclip.
    **Hindsight is always 1080p**
  • Patrice Freymond
    November 27, 2010 at 8:14 am
    1) DVD footage is not a broadcasting format or destined to be edited
    2) iTunes… are you monitoring this on a proper broadcast monitor or just on your computer?
    3) What are you tryng to achieve? Best workflow to preserve whatever quality is there will depend on this too.
    patrice
  • Chris Tompkins
    November 27, 2010 at 12:57 pm
    Use MPEG streamclip (free) to rip the DVD
    Rip the file to dv50
    Import into FCP.
    Chris Tompkins
    Video Atlanta LLC
  • Atticus Brady
    November 27, 2010 at 5:02 pm
    Thanks everyone for the prompt responses. Chris, here’s what happens when I try using MPEG streamclip: I open the DVD and I get a “File open error: the first part of the file is not valid” error message. I choose to “open anyway”. I apply the settings you recommended (export to QT – Apple Pro Res – 720×480 – lower field first, frame blending, interlace scaling – uncompressed stereo audio, etc. Upon saving to an external FW drive, it got about 8% and then stopped, giving me a “could not convert sample rate” error message. When I opened the small file that was produced, it was just a thick green bar passing through the frame.
    Any sense of what is going on here or if there’s anything I’m doing incorrectly?
    AB
  • Chris Tompkins
    November 27, 2010 at 10:14 pm
    What I do is open the DVD in the Finder and drag the track(file) off the disc and onto the open ap – mpeg streamclip.
    Choose repair time-code breaks or what ever it says. CMD F will force it. Try this and see if it makes a diff.
    Let us know.
    Chris Tompkins
    Video Atlanta LLC
  • Atticus Brady
    November 28, 2010 at 10:45 pm
    Hi Chris – I opened the DVD in the finder and moved the VOB video files onto the open app. This time it asked me “Do you want to open this stream as a DVD?” I experimented with both yes and no, forcing it to fix the timecode breaks in the stream…but got the same result: it exports extremely slowly, gets about 12% then conks out, giving me that “sample rate” error message as it did earlier.
    I’m not one to give up, but I am tempted to have the DVDs converted to XD, then bring the XD files into my system with a BARE drive. If you have no other suggestions, do you think this is a respectable alternative?
  • Chris Tompkins
    November 29, 2010 at 1:11 pm
    Wow, sounds like that disc is corrupt or something.
    I don’t know anything about XD.
    Chris Tompkins
    Video Atlanta LLC
