Activity Forums Apple Final Cut Pro Legacy Quality loss? ProRes to ProRes
  • Quality loss? ProRes to ProRes
    Posted by Zack Braff on August 20, 2008 at 11:31 pm
    Hi All-
    My question is about re-encoding and quality loss. I have converted some AVCHD footage from an HG-10 into ProRes via Log and Transfer (ProRes HQ is not an available option). As it was shot via Canon’s 24p setting, I will be running it through Apple’s suggested Compressor work-flow for the Canon HV20. Now the question: is there any quality lost re-outputting to 8-bit ProRes when doing Compressor’s format conversion? Is there any advantage exporting as ProRes HQ? My feeling is that I should just output to the same 8-bit ProRes that I am starting off with.
    To note: some of this footage will be used as part of a documentary which will be going for a film out, so I do in fact want a 23.98 frame rate. Final delivery will be 720p 23.98 10-bit Uncompressed.
    Zack
    Zack Braff replied 18 years ago 3 Members · 9 Replies
  • 9 Replies
  • Jeremy Garchow
    August 21, 2008 at 12:03 am
    What’s 8 bit Prores?
  • Zack Braff
    August 21, 2008 at 12:36 am
    Did I get that wrong Jeremy? My understanding is that ProRes is 8-bit, ProRes HQ is 10-bit.
  • Jeremy Garchow
    August 21, 2008 at 12:43 am
    All ProRes is 10 bit. ProRes is 145 mb.sec HQ is 220 mb.sec.
    A reverse telecine should not recompress your footage at all, it will simply reconstruct it.
    Jeremy
  • Zack Braff
    August 21, 2008 at 12:59 am
    OK – as the reverse telecine will just be reconstructing the original ProRes footage, am I right in assuming that there will be no quality lost by staying with ProRes? In other words there is no advantage to exporting as ProRes HQ.
  • Jeremy Garchow
    August 21, 2008 at 1:00 am
    Yep. You’re good.
  • Zack Braff
    August 21, 2008 at 1:02 am
    OK. Great. Thanks Jeremy.
  • Jeremy Garchow
    August 21, 2008 at 1:07 am
    No worries.
    Have fun.
    Jeremy
  • Sean Oneil
    August 21, 2008 at 5:49 am
    This isn’t Zack Braff of Garden State is it? Sorry, had to ask.
    Sean
  • Zack Braff
    August 21, 2008 at 4:01 pm
    Sorry, no. But my wife and I have had to change our home phone number because of similar interest… 🙂
