Quality loss in after effects cs6
I’m using after effects cs6 on an iMac (not the new model, but the one before), 3.4 Ghz i7, 16 gb ram, amd radeon HD 6970M 2048 MB, OS X 10.8.2. I’m having a problem when I import footage (dv widescreen) into after effects and when I export it. The quality is a lot worse (even with it set to full quality and at 100%) in the viewer, and in the lossless export I have the same quality loss and the colors are messed up as well.
This is what the raw video looks like: https://images.creativecow.net/251995/raw.png
This is it after import into ae: https://images.creativecow.net/251995/ae.png
This is the lossless export: https://images.creativecow.net/251995/losslessexport.pngI tried uninstalling and reinstalling ae with no change. I haven’t messed with any setting or anything. Help?
