Activity › Forums › Adobe Premiere Pro › Quality loss in 16:9 export of anamorphic video
  • Quality loss in 16:9 export of anamorphic video
    Posted by Kurt Vincent on July 31, 2018 at 1:19 am
    Editing video in a timeline with sequence settings that match the anamorphic master video resolution (2880×2160) with the Pixel Aspect Ratio set to 2.0.
    When I export with settings that match the source clip the quality is lossless in my eyes. But…
    When I export to a 1920×1080 with letterbox it is slightly less sharp and muddy – clear to the eye.
    I am guessing it is something to do with the Pixel Aspect Ratio having to be turned to Square when exporting to 1920×1080.
    How should I export this anamorphic edit to 16:9?
    I am cutting a fundraising teaser for a doc and only have a few days before delivery eod…any advice regarding anamorphic workflow in Premiere would be appreciated. I have scoured the forums and am still trying to figure this out.
    Thanks in advance.
    -Kurt
    Chris Wright replied 8 years, 2 months ago 2 Members · 4 Replies
  • Chris Wright
    July 31, 2018 at 1:21 am
    what are you exporting for?
  • Kurt Vincent
    July 31, 2018 at 1:27 am
    YouTube/Vimeo.
    I will also need to export a high res version for colorist working in DaVinci.
  • Kurt Vincent
    July 31, 2018 at 1:59 am
    It just occurred to me – is the loss in sharpness in the 16:9 simply from the smaller resolution?
  • Chris Wright
    July 31, 2018 at 2:47 am
    its a big reduction in quality. you can upload 4k to youtube as youtube will automatically letterbox.
    as you have surmised, going from anamorphic to 16:9 won’t be pretty.
    Since:
    Aspect Ratio = (Horizontal Resolution / Vertical Resolution) × Pixel Aspect Ratio
    so your AR = 2.66666 square
    and 16:9 = 1.77 square
    To fit the player perfectly, encode at these resolutions:
    2160p: 3840×2160
    1440p: 2560×1440
    1080p: 1920×1080
    but if you had to keep AR, 2.6 square would be 1920/720 square pixels or 2880×1080.
    anamorphic videos will be letterboxed in both 16:9 and 4:3 players. The player can only do this if the native aspect ratio of the video is maintained – i.e. don’t add black bars to the video itself.
    Note: If you add letterboxing to a video before uploading it, the widescreen player will add vertical bars, resulting in black bars all around the video and a bad viewing experience.
