Quality loss exporting from FCP using QT converter for upload to Youtube
Hi, I’m using a Hauppauge HD PVR to capture video game footage for uploading to Youtube. I use Eye TV for recording, and when I export a video from there, the quality looks pretty good in quicktime. Then, I import it into Final Cut Pro, render, voice over, then export it using quicktime conversion. I make the size 1280×720, I choose MPEG-4 video, quality is set to best, and fps at current. After I export it, I notice the quality is diminished slightly, but it is noticeable. I’ve experimented with many different settings, but I come up with the same result or worse. Under capture settings, I have it to DV NTSC 48 kHz Anamorphic. I had changed this to anamorphic because before, I was getting letterboxing, and switching to anamorphic seemed to fix that. Under sequence>settings, the frame size is at 720×480, NTSC DV (3:2). Pixel aspect ratio is set to NTSC – CCIR 601 DV (720×480). Compressor is set to DV/DVCPRO – NTSC. I tried changing the frame size to 1280×720 HDTV 720p (16:9), but that shrunk the video in my canvas window, and after exporting, it looked even worse. I know this is a lot of info, but I figure I’d have to give it eventually, haha. Any help on how to keep the original quality would be appreciated.
