Activity Forums Apple Final Cut Pro Legacy Quality Loss
  • Posted by Elaine Lake on June 4, 2011 at 10:33 pm
    I imported an Adobe AE .mov animation I made into a Final Cut Project. It looks fine in the FCP viewer but when I render the project, the animation looks terrible!
    My sequence settings in Final Cut are:
    NTSC 720×480 NTSC DV 3:2
    Compressor is DV / DVCPRO – NTSC
    I shot footage on a Canon 7D camera and transcoded it to Apple Pro Res 422 LT to work with it in FCP.
    Any idea why the AE files looks blurry and loses quality when I export my FCP project with it in it?
    Thank you in advance for your help!
    Elaine Lake replied 15 years, 3 months ago 2 Members · 2 Replies
  • David Roth weiss
    June 4, 2011 at 11:13 pm
    This is a very common issue Elayne, and it’s quite simple to fix.
    The problem is, you’ve put your title in a DV sequence. DV compression is as bad as it gets. Create a new sequence with settings to match your ProRes LT footage, and drop the animation in, and you’ll see a remarkable difference.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Elaine Lake
    June 6, 2011 at 3:25 am
    Thank you very much! 🙂
